Try flashing couple of older versions… I would say try another set of different usb cables.
I have tried that as well.
I used multiple mini usb cables that i use to transfer data from my android, but i received the same result.
I just tried flashing it with clean flight as well but i got the same thing as BF.
I am starting to think there is something wrong with the FC!
@blackhole do you have any I2C error on your board when you configure it with BF?
@ntsami Im not with my drone so cant check for at least a week. The usb I checked was a samsung usb cable which can transfer phone data across but didn’t work for the flight controller. Keep trying usb cables…
Enter this in CLI if you have Matek F722-STD :
set baro_hardware = BMP280
It should fix some I2C errors
Olivier
