Aurora 90 rx issue (betaflight not saving sbus)
Hello,
I recently saw a mini fpv course at the London Comic Con. Looked very exciting so I have managed to come by an Aurora90 and Taranis Q7 (Goggles on the way from unmanned tech).
I managed to get a couple of flights and all seemed good. However I have turned on this morning (a few days after the working flights) and I can’t get the thing to trigger. In between working and not working flights I have added an SD card with sounds to the Q7, and hooked up to BetaFlight a few times (I don’t think I hit save at any time, but who knows).
I hooked it up to BetaFlight (3.2.0) after it wasn’t working and the receiver configuration looks to be where the fault lies.
(1) The receiver page looks like this:
There are no coloured bars.
(2) Looking at the serial configuration I have UART3 set to serialRx:
(I was going to put a pic here of port configuration, but new users can only post 2 pics!)
(3) The Receiver configuration is set to “serial based receiver”. But the provider keeps being reset to “spektrum1024” (which I assume is where the problem is). Whenever I save and reboot it never seems to hold the “SBUS” setting which I think I need.
If I change other configuration (like LED strip) the configuration appears to persist.
I have visually looked at the solder joints for the 3 connectors between the frSky receiver
board and the Minicube F3 Flight Controller and it looks ok (but I haven’t got the multimeter on it yet).
Can anyone suggest what maybe wrong with the configuration saving and even if I am on the right track with the SBUS thing. The Tx informs telemetry lost/recovered when I plug and unplug the quad.
Any help will be much appreciated,
Dave.
I know sometimes it does not save properly so I suggest you disable serial Rx on the ports tab, then save. Then try select the sbus setting in config tab, might have to try this a few times before it works.
Also you say you connect it to betaflight 3.2… did you flash betaflight 3.2 onto your board? If so what target did you select? But for now I suggest you stick with 3.1.7.
Also just read this post that has the exact same problem but with a different FC so think there might be a bug somewhere. Basically the firmware update messed up reciever settings but also set all endpoints to 0. See the post below for more details.
Hi Alex,
Thank you so much for the fast response! I have not reflashed the drone (I don’t know how yet!), but I have tried the save dance (disable uart3, save, set reciever mode, save, enable uart3, save, reset the receiver mode) … and it seems to be holding the sbus configuration.
Thanks for the link to the chap with a similar issue. My receiver settings were also all zero. I have set the min to 1000, mid to 1500 and max to 2000. It is still not working, but I do now get the bars for roll, pitch and yaw flashing intermittently up to 1500. So I think I have a similar issue to the linked post. He mentions having to reset failsafe values. So I’ll investigate this; as from an initial glance I can’t find the failsafe settings (I know, noob).
I’ll continue investigating.
Thanks again.
OK, I found the failsafe tab by enabling expert mode.
The min and max length values were 0, as your other contributor suggested. I have set these to 885 and 2115 respectively (based on a page I found on the internet - I assume these are reasonable).
I now seem to have working receiver bars. I’m stoked.
I’ll go and try it and see what happens!
It flies! Just took a spin around the living room; much to the annoyance of the wife.
So I’m not sure why betaflight had set all the rx and failsafe values to 0; but setting them to 1000, 1500, 2000, 885 and 2115 has got me flying again.
Thanks again for you help Alex.
I just need those goggles I ordered from you and I’ll get my first taste of FPV.
Happy to hear you got it all working and I’m sure you will have lots of fun with fpv, but takes abit of getting used to at first so make sure you fly in a big open area!
Thank you guys for your thread my drones have been grounded for 2 weeks because of this. And no one understood me when I said that they were previously set up and all I did was plug them into betaflight and now they’re tweaked. But now that I know it wasn’t me going crazy and it was betaflight I will be emailing them back and directing them to this site. I know they won’t refund my money for 3 flight controllers and 2 laptops! But thank you guys for the 30 second fix!
Hi KyleDronesToo,
I’m glad you found the solution. I was frustrated after a few hours; can’t imagine a few weeks!
Hello, I had the same issue with my Aurora , so I flashed everything B-heli, Betaflight and have the channels working again but like how it was when I just bound my Qx7 to the Aurora, I get major 1 sec latency with all channels. I don’t know why this is happening, I’ve placed the transmitter far enough away from the Aurora…but still I move the stick and 1 second later, I see the effect on Betaflight, , why am I getting a 1 sec delay…Thanks…
Hi Static8,
I’m new to all of this I’m afraid. I didn’t have the 1 second delay issue with mine.
(a) Does the drone work normally when flying (i.e. is it just a betaflight display issue)
(b) Could your PC be underpowered (I’m using a MacBook)?
Maybe an expert could chip in.
Dave.
No it was like this out of box…It was taking a second for any input to reach the Aurora. Reason why I connected it to Betaflight…
Hi Static8,
Not sure if this will help, but you can load my exact configuration for my aurora90,via the cli.
Assuming the forum markdown formatting doesn’t kill the content, here it is:
dump all
Betaflight / OMNIBUS 3.1.7 Apr 3 2017 / 22:14:20 (e1c4b5c)
name Aurora 90
resource BEEPER 1 C15
resource MOTOR 1 B08
resource MOTOR 2 B09
resource MOTOR 3 A03
resource MOTOR 4 A02
resource MOTOR 5 B07
resource MOTOR 6 B06
resource MOTOR 7 NONE
resource MOTOR 8 NONE
resource MOTOR 9 NONE
resource MOTOR 10 NONE
resource MOTOR 11 NONE
resource MOTOR 12 NONE
resource SERVO 1 NONE
resource SERVO 2 NONE
resource SERVO 3 NONE
resource SERVO 4 NONE
resource SERVO 5 NONE
resource SERVO 6 NONE
resource SERVO 7 NONE
resource SERVO 8 NONE
resource PPM 1 B04
resource PWM 1 NONE
resource PWM 2 NONE
resource PWM 3 NONE
resource PWM 4 NONE
resource PWM 5 NONE
resource PWM 6 NONE
resource PWM 7 NONE
resource PWM 8 NONE
resource LED_STRIP 1 A08
resource SERIAL_TX 1 A09
resource SERIAL_TX 2 A14
resource SERIAL_TX 3 B10
resource SERIAL_TX 4 NONE
resource SERIAL_TX 5 NONE
resource SERIAL_TX 6 NONE
resource SERIAL_TX 7 NONE
resource SERIAL_TX 8 NONE
resource SERIAL_TX 9 NONE
resource SERIAL_TX 10 NONE
resource SERIAL_TX 11 NONE
resource SERIAL_TX 12 NONE
resource SERIAL_RX 1 A10
resource SERIAL_RX 2 A15
resource SERIAL_RX 3 B11
resource SERIAL_RX 4 NONE
resource SERIAL_RX 5 NONE
resource SERIAL_RX 6 NONE
resource SERIAL_RX 7 NONE
resource SERIAL_RX 8 NONE
resource SERIAL_RX 9 NONE
resource SERIAL_RX 10 NONE
resource SERIAL_RX 11 NONE
resource SERIAL_RX 12 NONE
mixer QUADX
mmix reset
servo 0 1000 2000 1500 45 45 100 -1
servo 1 1000 2000 1500 45 45 100 -1
servo 2 1000 2000 1500 45 45 100 -1
servo 3 1000 2000 1500 45 45 100 -1
servo 4 1000 2000 1500 45 45 100 -1
servo 5 1000 2000 1500 45 45 100 -1
servo 6 1000 2000 1500 45 45 100 -1
servo 7 1000 2000 1500 45 45 100 -1
smix reset
feature -RX_PPM
feature -VBAT
feature -INFLIGHT_ACC_CAL
feature -RX_SERIAL
feature -MOTOR_STOP
feature -SERVO_TILT
feature -SOFTSERIAL
feature -GPS
feature -FAILSAFE
feature -SONAR
feature -TELEMETRY
feature -CURRENT_METER
feature -3D
feature -RX_PARALLEL_PWM
feature -RX_MSP
feature -RSSI_ADC
feature -LED_STRIP
feature -DISPLAY
feature -OSD
feature -BLACKBOX
feature -CHANNEL_FORWARDING
feature -TRANSPONDER
feature -AIRMODE
feature -SDCARD
feature -VTX
feature -RX_SPI
feature -SOFTSPI
feature -ESC_SENSOR
feature -FEATURE_ANTI_GRAVITY
feature VBAT
feature RX_SERIAL
feature MOTOR_STOP
feature FAILSAFE
feature CURRENT_METER
feature LED_STRIP
feature OSD
beeper GYRO_CALIBRATED
beeper RX_LOST
beeper RX_LOST_LANDING
beeper DISARMING
beeper ARMING
beeper ARMING_GPS_FIX
beeper BAT_CRIT_LOW
beeper BAT_LOW
beeper GPS_STATUS
beeper RX_SET
beeper ACC_CALIBRATION
beeper ACC_CALIBRATION_FAIL
beeper READY_BEEP
beeper MULTI_BEEPS
beeper DISARM_REPEAT
beeper ARMED
beeper SYSTEM_INIT
beeper ON_USB
map TAER1234
serial 20 1 115200 57600 0 115200
serial 0 1 115200 57600 0 115200
serial 1 0 115200 57600 0 115200
serial 2 64 115200 57600 0 115200
led 0 0,7::COI:0
led 1 7,7::CTO:0
led 2 8,7::CTO:0
led 3 15,7::COI:0
led 4 0,0::C:0
led 5 0,0::C:0
led 6 0,0::C:0
led 7 0,0::C:0
led 8 0,0::C:0
led 9 0,0::C:0
led 10 0,0::C:0
led 11 0,0::C:0
led 12 0,0::C:0
led 13 0,0::C:0
led 14 0,0::C:0
led 15 0,0::C:0
led 16 0,0::C:0
led 17 0,0::C:0
led 18 0,0::C:0
led 19 0,0::C:0
led 20 0,0::C:0
led 21 0,0::C:0
led 22 0,0::C:0
led 23 0,0::C:0
led 24 0,0::C:0
led 25 0,0::C:0
led 26 0,0::C:0
led 27 0,0::C:0
led 28 0,0::C:0
led 29 0,0::C:0
led 30 0,0::C:0
led 31 0,0::C:0
color 0 0,0,0
color 1 0,255,255
color 2 0,0,255
color 3 30,0,255
color 4 60,0,255
color 5 90,0,255
color 6 120,0,255
color 7 150,0,255
color 8 180,0,255
color 9 210,0,255
color 10 240,0,255
color 11 270,0,255
color 12 300,0,255
color 13 330,0,255
color 14 0,0,0
color 15 0,0,0
mode_color 0 0 1
mode_color 0 1 11
mode_color 0 2 2
mode_color 0 3 13
mode_color 0 4 10
mode_color 0 5 3
mode_color 1 0 5
mode_color 1 1 11
mode_color 1 2 3
mode_color 1 3 13
mode_color 1 4 10
mode_color 1 5 3
mode_color 2 0 10
mode_color 2 1 11
mode_color 2 2 4
mode_color 2 3 13
mode_color 2 4 10
mode_color 2 5 3
mode_color 3 0 8
mode_color 3 1 11
mode_color 3 2 4
mode_color 3 3 13
mode_color 3 4 10
mode_color 3 5 3
mode_color 4 0 7
mode_color 4 1 11
mode_color 4 2 3
mode_color 4 3 13
mode_color 4 4 10
mode_color 4 5 3
mode_color 5 0 9
mode_color 5 1 11
mode_color 5 2 2
mode_color 5 3 13
mode_color 5 4 10
mode_color 5 5 3
mode_color 6 0 6
mode_color 6 1 10
mode_color 6 2 1
mode_color 6 3 0
mode_color 6 4 0
mode_color 6 5 2
mode_color 6 6 3
mode_color 6 7 6
mode_color 6 8 0
mode_color 6 9 0
mode_color 6 10 0
mode_color 7 0 3
aux 0 0 0 1400 2100
aux 1 28 1 1300 2100
aux 2 1 1 900 1600
aux 3 2 1 1800 2100
aux 4 13 2 1700 2100
aux 5 0 0 900 900
aux 6 0 0 900 900
aux 7 0 0 900 900
aux 8 0 0 900 900
aux 9 0 0 900 900
aux 10 0 0 900 900
aux 11 0 0 900 900
aux 12 0 0 900 900
aux 13 0 0 900 900
aux 14 0 0 900 900
aux 15 0 0 900 900
aux 16 0 0 900 900
aux 17 0 0 900 900
aux 18 0 0 900 900
aux 19 0 0 900 900
adjrange 0 0 0 900 900 0 0
adjrange 1 0 0 900 900 0 0
adjrange 2 0 0 900 900 0 0
adjrange 3 0 0 900 900 0 0
adjrange 4 0 0 900 900 0 0
adjrange 5 0 0 900 900 0 0
adjrange 6 0 0 900 900 0 0
adjrange 7 0 0 900 900 0 0
adjrange 8 0 0 900 900 0 0
adjrange 9 0 0 900 900 0 0
adjrange 10 0 0 900 900 0 0
adjrange 11 0 0 900 900 0 0
adjrange 12 0 0 900 900 0 0
adjrange 13 0 0 900 900 0 0
adjrange 14 0 0 900 900 0 0
rxrange 0 1000 2000
rxrange 1 1000 2000
rxrange 2 1000 2000
rxrange 3 1000 2000
rxfail 0 a
rxfail 1 a
rxfail 2 a
rxfail 3 a
rxfail 4 h
rxfail 5 h
rxfail 6 h
rxfail 7 h
rxfail 8 h
rxfail 9 h
rxfail 10 h
rxfail 11 h
rxfail 12 h
rxfail 13 h
rxfail 14 h
rxfail 15 h
rxfail 16 h
rxfail 17 h
set task_statistics = ON
set mid_rc = 1500
set min_check = 1000
set max_check = 2000
set rssi_channel = 9
set rssi_scale = 30
set rc_interp = AUTO
set rc_interp_ch = RP
set rc_interp_int = 19
set rssi_invert = OFF
set input_filtering_mode = OFF
set fpv_mix_degrees = 0
set max_aux_channels = 6
set debug_mode = NONE
set min_throttle = 1050
set max_throttle = 2000
set min_command = 1000
set digital_idle_percent = 3.000
set 3d_deadband_low = 1406
set 3d_deadband_high = 1514
set 3d_neutral = 1460
set 3d_deadband_throttle = 0
set use_unsynced_pwm = OFF
set motor_pwm_rate = 400
set disarm_kill_switch = ON
set gyro_cal_on_first_arm = OFF
set auto_disarm_delay = 5
set small_angle = 25
set fixedwing_althold_dir = 1
set reboot_character = 82
set serial_update_rate_hz = 100
set beeper_inversion = ON
set beeper_od = OFF
set serialrx_provider = SBUS
set sbus_inversion = ON
set spektrum_sat_bind = 0
set spektrum_sat_bind_autorst = 1
set tlm_switch = OFF
set tlm_inversion = ON
set sport_halfduplex = ON
set frsky_default_lat = 0.000
set frsky_default_long = 0.000
set frsky_gps_format = 0
set frsky_unit = IMPERIAL
set frsky_vfas_precision = 0
set frsky_vfas_cell_voltage = OFF
set hott_alarm_int = 5
set pid_in_tlm = OFF
set bat_capacity = 0
set vbat_scale = 110
set vbat_max_cell_voltage = 43
set vbat_min_cell_voltage = 33
set vbat_warning_cell_voltage = 35
set vbat_hysteresis = 1
set ibat_scale = 400
set ibat_offset = 0
set mwii_ibat_output = OFF
set current_meter_type = ADC
set battery_meter_type = ADC
set bat_detect_thresh = 55
set use_vbat_alerts = ON
set use_cbat_alerts = OFF
set cbat_alert_percent = 10
set align_gyro = DEFAULT
set align_acc = DEFAULT
set align_mag = DEFAULT
set align_board_roll = 0
set align_board_pitch = 0
set align_board_yaw = 0
set gyro_lpf = OFF
set gyro_sync_denom = 1
set gyro_isr_update = OFF
set gyro_use_32khz = OFF
set gyro_lowpass_type = PT1
set gyro_lowpass = 90
set gyro_notch1_hz = 400
set gyro_notch1_cut = 300
set gyro_notch2_hz = 200
set gyro_notch2_cut = 100
set moron_threshold = 32
set imu_dcm_kp = 2500
set imu_dcm_ki = 0
set alt_hold_deadband = 40
set alt_hold_fast_change = ON
set deadband = 0
set yaw_deadband = 0
set thr_corr_value = 0
set thr_corr_angle = 800
set yaw_control_direction = 1
set yaw_motor_direction = 1
set servo_center_pulse = 1500
set tri_unarmed_servo = ON
set servo_lowpass_hz = 400
set servo_lowpass = OFF
set servo_pwm_rate = 50
set gimbal_mode = NORMAL
set channel_forwarding_start = 4
set airmode_start_throttle = 1350
set failsafe_delay = 10
set failsafe_off_delay = 10
set failsafe_throttle = 1000
set failsafe_kill_switch = OFF
set failsafe_throttle_low_delay = 100
set failsafe_procedure = DROP
set rx_min_usec = 884
set rx_max_usec = 2115
set acc_hardware = AUTO
set acc_lpf_hz = 10
set accxy_deadband = 40
set accz_deadband = 40
set acc_unarmedcal = ON
set acc_trim_pitch = 0
set acc_trim_roll = 0
set baro_tab_size = 21
set baro_noise_lpf = 0.600
set baro_cf_vel = 0.985
set baro_cf_alt = 0.965
set baro_hardware = NONE
set mag_hardware = NONE
set mag_declination = 0
set pid_process_denom = 4
set blackbox_rate_num = 1
set blackbox_rate_denom = 1
set blackbox_device = SDCARD
set blackbox_on_motor_test = OFF
set magzero_x = 0
set magzero_y = 0
set magzero_z = 0
set ledstrip_visual_beeper = OFF
set sdcard_dma = OFF
set osd_units = METRIC
set osd_rssi_alarm = 20
set osd_cap_alarm = 2200
set osd_time_alarm = 10
set osd_alt_alarm = 100
set osd_vbat_pos = 2060
set osd_rssi_pos = 2423
set osd_flytimer_pos = 2454
set osd_ontimer_pos = 2422
set osd_flymode_pos = 2445
set osd_throttle_pos = 129
set osd_vtx_channel_pos = 200
set osd_crosshairs = 2048
set osd_horizon_pos = 2248
set osd_current_pos = 97
set osd_mah_drawn_pos = 111
set osd_craft_name_pos = 2434
set osd_gps_speed_pos = 66
set osd_gps_sats_pos = 1410
set osd_altitude_pos = 161
set osd_pid_roll_pos = 322
set osd_pid_pitch_pos = 354
set osd_pid_yaw_pos = 386
set osd_power_pos = 47
set osd_pidrate_profile_pos = 418
set osd_battery_warning_pos = 200
set vcd_video_system = 0
set vcd_h_offset = 0
set vcd_v_offset = 0
set displayport_msp_col_adjust = 0
set displayport_msp_row_adjust = 0
set displayport_max7456_col_adjust = 0
set displayport_max7456_row_adjust = 0
profile 0
set pidsum_limit = 0.500
set pidsum_limit_yaw = 0.500
set d_lowpass_type = BIQUAD
set d_lowpass = 100
set d_notch_hz = 260
set d_notch_cut = 160
set vbat_pid_gain = OFF
set pid_at_min_throttle = ON
set anti_gravity_thresh = 350
set anti_gravity_gain = 3.000
set setpoint_relax_ratio = 30
set d_setpoint_weight = 60
set yaw_accel_limit = 10.000
set accel_limit = 0.000
set iterm_windup = 50
set yaw_lowpass = 0
set p_pitch = 58
set i_pitch = 50
set d_pitch = 22
set p_roll = 43
set i_roll = 40
set d_roll = 20
set p_yaw = 70
set i_yaw = 45
set d_yaw = 20
set p_alt = 50
set i_alt = 0
set d_alt = 0
set p_level = 50
set i_level = 50
set d_level = 100
set p_vel = 55
set i_vel = 55
set d_vel = 75
set level_sensitivity = 55
set level_limit = 55
rateprofile 0
rateprofile 0
set rc_rate = 100
set rc_rate_yaw = 100
set rc_expo = 0
set rc_yaw_expo = 0
set thr_mid = 50
set thr_expo = 0
set roll_srate = 70
set pitch_srate = 70
set yaw_srate = 70
set tpa_rate = 10
set tpa_breakpoint = 1650
rateprofile 1
set rc_rate = 100
set rc_expo = 0
set rc_yaw_expo = 0
set thr_mid = 50
set thr_expo = 0
set roll_srate = 70
set yaw_srate = 70
set tpa_rate = 10
rateprofile 2
set rc_rate = 100
set rc_expo = 0
set rc_yaw_expo = 0
set thr_mid = 50
set thr_expo = 0
set roll_srate = 70
set yaw_srate = 70
set tpa_rate = 10
rateprofile 0
profile 1
set d_lowpass = 100
set yaw_lowpass = 0
set p_pitch = 58
set i_pitch = 50
set d_pitch = 22
set p_roll = 43
set i_roll = 40
set d_roll = 20
set p_yaw = 70
set i_yaw = 45
set d_yaw = 20
set p_alt = 50
set i_alt = 0
set d_alt = 0
set p_level = 50
set i_level = 50
set d_level = 100
set p_vel = 55
set i_vel = 55
set d_vel = 75
rateprofile 0
rateprofile 0
set rc_rate = 100
set rc_expo = 0
set rc_yaw_expo = 0
set thr_mid = 50
set thr_expo = 0
set roll_srate = 70
set yaw_srate = 70
set tpa_rate = 10
rateprofile 1
set rc_rate = 100
set rc_expo = 0
set rc_yaw_expo = 0
set thr_mid = 50
set thr_expo = 0
set roll_srate = 70
set yaw_srate = 70
set tpa_rate = 10
rateprofile 2
set rc_rate = 100
set rc_expo = 0
set rc_yaw_expo = 0
set thr_mid = 50
set thr_expo = 0
set roll_srate = 70
set yaw_srate = 70
set tpa_rate = 10
rateprofile 0
profile 2
set d_lowpass = 100
set yaw_lowpass = 0
set p_pitch = 58
set i_pitch = 50
set d_pitch = 22
set p_roll = 43
set i_roll = 40
set d_roll = 20
set p_yaw = 70
set i_yaw = 45
set d_yaw = 20
set p_alt = 50
set i_alt = 0
set d_alt = 0
set p_level = 50
set i_level = 50
set d_level = 100
set p_vel = 55
set i_vel = 55
set d_vel = 75
rateprofile 0
rateprofile 0
set rc_rate = 100
set rc_expo = 0
set rc_yaw_expo = 0
set thr_mid = 50
set thr_expo = 0
set roll_srate = 70
set yaw_srate = 70
set tpa_rate = 10
rateprofile 1
set rc_rate = 100
set rc_expo = 0
set rc_yaw_expo = 0
set thr_mid = 50
set thr_expo = 0
set roll_srate = 70
set yaw_srate = 70
set tpa_rate = 10
rateprofile 2
set rc_rate = 100
set rc_expo = 0
set rc_yaw_expo = 0
set thr_mid = 50
set thr_expo = 0
set roll_srate = 70
set yaw_srate = 70
set tpa_rate = 10
rateprofile 0
profile 0
save
It’s for an frSky rx’er btw
WOuld you just copy and paste in CLI…?..I flashed the newer version, maybe I shoud go back to this one?..Just wondering FC contoller is Ominibus , is that the correct one to choose as my FC would not automatically tell me…
Thanks, sorry newbie questions.
I have 3.21…newest…Maybe flash with 3.17?
Now I think about it…It came with 3.1.7 and had same issue reaso why I upgraded…arghh!!.
Yep, just cut and paste into cli. I watched on youtube somewhere that people recommend pasting in, in batches (i.e. not all at once). I would recommend saving your current config first. Just issue the ‘dump all’ command and save resulting text away. Then you can go back if needed.
OMNIBUS is the one you want for the aurora90, btw.
Mine is a few months old now, so may be out of date version wise.
OKwill try it out later today…at least Banggood provided me 75 percent refund for my troubles…so if its receiver I can always buy another and learn how to put a new one in or just buy a new 90mm. , maybe the Lizard I hear their great little micro quad using xm receiver I know that works on my transmitter lol…thanks for your help,if it works I willl let you know…
I got the lizard95 as well as an aurora90. I like it, but I had a few issues with it. (1) the usual motor screw shorting issue (I just removed 3 screws from the motors), but should really shim with a soft mount. (2) The camera is crappy. It overheats, the 100mw mode killed the frsky signal (so have to run in 25mw), the picture is very overexposed for me (compare to the aurora).
