Can a 2212 2200kv Motor lift a f450 Frame?
Hi @yash_behera
The answer is YES …
providing you use at least a 35C pack if you want to stay with 3S
This is based on all up weight of 950g
Thrust/weight ratio is about 3:1 which is good but battery load is bad, hover current is about 15A and at maximum thrust is as high as 94A !!
You’ll only get about 4.7minutes of flight time (7.5 hovering)
So again YES, but not the best choice
(I used ecalc for this modelling, worth you trying various combinations until you arrive at your needs)
Hope this helps
Steve :slight_smile:
