Hello,
I just bought a FTDI Basic from Unmanned Tech and I have a question regarding the connection to the RTF Pixel Led Ring. If I look the labelled pins, I have DTR-TXO-RX1-VCC5-GND-GND on the RTF Pixel side and 3V3-RTS-TXD-RXD-GND-5V on the FTDI Basic side. Can connect them directly to program the Led Ring or do I need a special cable?
Thanks in advance for your help…
With kind regards,
Olivier
I have found some information on the net and I connected both items the following way:
5V => VCC5
GND => GND
TXD => RX1
RXD => TX0
DTR, 3V3, RTS and the last GND were left unconnected.
I tried to upload to the Arduino-Atmel board of the RTFpixel Led Ring, but get the following error:
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
Anyone has an idea what’s going on or a link where I could find a tutorial how to program those led rings?
Olivier
Anyone knows which board and which programmer I have to choose in the Arduino IDE?
Regarding the connexion, normally DTR should go to DSR and RTS to CTS.
The only cable left are DTR/GND on the RTF pixel led ring and 3V3/RTS on the FTDI basic side.
Do I leave those cables unconnected?
