Colors and blinking modes work fine when using the switch on the board directly. However, this board has a feature where you can control colors via PWM, so you can turn a knob on your TX and switch through 7 colors.
Has anyone got this to work?
What I tried is:
- The prefered way, described in matek video: Channel forwarding managed by Betaflight - no color change
- To eliminate possible fuckups in my betaflight config, I connected channel 3 of my crossfire RX to the board and configured it to output PWM - still no color change
- To eliminate any possible fuckup I wired the stuff like in the 90ies: Got an old pwm receiver and connected a servo to port 1 and the LED board to port 2. While the servo moves when I move the sticks so PWM signal is fine but the LED colors still don’t change.
I tried this with all 3 LED controllers I got from unmannedtech - no difference.
