So Does NAZ Rev6A-C fix the Power Problem with USB Plug and ESC’s?
I am building my first Drone from the ground up. Initially I was using a KISS-FC but the BlHeli issues drove me away and I decided to switch up to a NAZ32 Rev6B. I have read in a number of places that the initial releases last year had a tendency to create the “Magic Smoke” when you hooked up the USB for setup and calibration. This happens if you follow directions and have the ESC’s connected. WHich it seems you have to do if your calibrating or updating the ESC Firmware. I have some confusion if this was happening with or with out the Lipo connected. Apparently the lack of a BEC and diode was feeding back too much power resulting in burnt out boards and controllers.
This issue to my understanding was resolved with Rev6A forward by adding the diode you now find in close proximity to the USB. SO this means you can follow the initial setup instructions and connect the USB interface followed by the Lipo, right?
I am at that point in the build and honestly I don’t want to deal with any more pain after spending untold hours for a week struggling like I did with that Flyduino KISS FC. Any and all direction is GREATLY appreciated. I really like this forum above all others I have found on Drones.
-STUCARIUS-
) However its always best practice to plug in your battery if you plan to test/calibrate your ESC’s then this problem would not occur in the first place, even with 6A boards.
Also remember to remove the props too
Drone pilots need to make up t-shirts. That’s becoming the Drone Pilots mantra
