Order Number: UT-704063-WH/OUT/45938
Product Name: Walksnail Nano Vtx V3
Brand: Caddx
Since trying to set up my new Walksnail system on my quad FC running INav 7.1, I’ve always had a random OSD display (info comes and goes), and the image jitters, is out of focus when looking at objects in the distance.
I have tried many, many things (Goggle settings - frame rate, resolution, different OSD settings, power settings etc) - basically with no change.
I also tried using it on a different flight controller - but only static, and also using Betaflight (instead of INav). Even the different FC shows random OSD elements, but I don’t know about the image quality on Betaflight whilst flying as it was not installed in a quad.
I have had a multiple email communication with you, and can try nothing more.
Changed many setting in the Goggles (frame rate, resolution, different OSD settings, power settings etc) - basically with no change.
I have also tried using it on a different flight controller - but only static, and also using Betaflight (instead of INav). The Betaflight FC also shows random OSD elements, but I don’t know about the image quality on Betaflight whilst flying, as it was not installed in a quad.
Both FC show an analogue image fine, using my Fatshark goggles and camera.
