Order Number: 700102
Product Name: Walksnail Avatar V2
Brand: Walksnail
Set up fine , on second flight landed and lost video , no led on V2 . No bumps or crashes , foamy feet on drone . Only using 4s setup. This my second unit with same issue.
Was Flashed with latest firmware 38 xx xx . After second v2 packed up I connected power supply for vtx to voltmeter and bounced the drone over the bench . Voltage stable
Sorry about this, I have been talking with Caddx about the issue and it would seem that we will need to return it back for further inspection/repairs as they would like to figure out why the unit is so fragile since its odd that its happened 2 times in a row on your same build. I should have an update soon so we can arrange the next steps for you…
Kind Regards
Well I fitted a vista yesterday, same set up . Flew some packs through it , deliberately bounced it on landing , no issues.
I think it’s well documented on walksnail system.
Mads tech Live stream walksnail repair shows BEC going down and boiling the dialog chip , which sounds about right. His comments on avatar system last week were good if you can put up with vtx going down.
People have lost multiple vtx’s , one person lost 3.
Walksnail don’t stipulate any particular mounting method or wiring method other than using a cap on 6s.
Would say some of these vtx’s are quite fragile and not fit for purpose. So I’m going to say it’s a walksnail issue.
Thanks for Replying.
