Order #736518 - Seeeduino Xiao Expansion Board Sku: 5f0-3b7-Af9 - Overheating when connecting ESP module and no LEDS
Order Number: 736518
Product Name: Seeeduino Xiao Expansion Board Sku: 5f0-3b7-Af9
Brand: Seeed Studio
The ESP32 device works fine disconnected to the board and I was testing with a simple Blink application connected to an LED and 270 Ohm resistor.
It appears to get very hot under the ESP device and is not powering up. When I disconnect the ESP from the expansion board the circuit works fine. It seems to be an issue with the Expansion board. No LEDS light up on the Expansion board when I connect USB power to the ESP device.
ESP32 works fine with Blink and external LED and 270 ohm resistor when disconnected to the Expansion board so I do not believe I have wired it incorrectly.
Hi Stephen good day,
I’m sorry to hear you are struggling like this, that is really frustrating.
I have already sent your description and photos through to Seeed and have asked their technical team for assistance.
As soon as I hear back from them I will come back to you.
David
Apologies for the delay. Good news, the manufacturer has agreed to replace the unit for you and did also apologies for the inconvenience caused.
Currently we do have stock of this item, so I can either send you one out to replace it or I can give you a full refund for the unit.
Please let me know which you would prefer and I can action that for you?
Hope this helps.
David
Hi David,
That’s great news, if you can send me a replacement that would be great. Do you need the other one sending back?
Best regards,
Stephen
Don’t stress about sending the old one back, that will just waste more of your time.
Good news your replacement is getting packed up and will be sent out later today.
David
Thanks David, Much appreciated.
Stephen
