Need help in installing 1k resistor on I2c pads
Need help in installing 1k resistor on FC OmniNXT F7, it says it in their product description. Any pic wold help me solve this issue.
It seems that you need to install pull-up resistors to make I2C sensor operative. The installation: connect two resistors connecting + (VCC: 5V or 3.3V; depends on application) on SDA and SCL each. I would rather use 4k7 instead1k.
Does it need to be installed on GPS puck or the FC
Could u share a picture to make it clear
Doesn’t matter. Pull-up resistors are just to add power to lines on communication. Either side is OK. Depends on empty space.
