Order Number: #UT-698078-WH/OUT/42895
Product Name: Motor Heewing
Brand: Heewing
Good morning, I am writing to you regarding a complaint about the engine I bought from you. Unfortunately, I only had the opportunity to test it today due to the bad weather that prevailed in the past few days. Unfortunately, there were problems during testing, which will be described in more detail below. The wing took off, but at the very beginning it behaved strangely in the air, it was constantly shaking and the power was weak, after 4 minutes of flight, out of nowhere in the air, my engine stopped working. rather it vibrated, I tested the ESC, but it was fine, could we come to an agreement, to claim only the engine? Sincerely, Zbyněk Bureš
I changed the engine, another engine worked, so the problem is in the engine. I didn’t do anything with the engine, it was my first flight. Without a single fall or visible damage to the engine
Thank you for reaching out to us regarding the issue with your motor. We have forwarded your request to Heewing to see if we can get a replacement authorized for you.
In order to assist you better, could you please provide us with some additional details about your setup? Specifically, we need to know:
- What propeller were you using?
- Do you have any DVR footage of the flight?
- What battery were you using?
From the photo you provided, it seems that the coils have burnt, which indicates that the motor got too hot. Since a motor is essentially just some wire wound around a magnet, this usually happens due to an external factor. It could be something like the motor screw damaging the coils. To help us diagnose the issue more accurately, could you also send a photo of the underside of the motor, preferably with the bell removed so we can show Heewing that the coils are not damaged by this?
Your cooperation will help us expedite the process and find a suitable solution for you.
Thank you for your understanding and assistance.
Hello, I used a 6x4E propeller. I snake and 4s 1500mah battery. Video from the wing https://youtu.be/adsoj18hOsY?si=_PwRiSrIZhGK0OIM
Best guards
Zbyněk Bureš
Dne st 18. 9. 2024 22:37 uživatel Unmanned Tech Support via DroneTrest <forum@dronetrest.com> napsal:
Dne čt 19. 9. 2024 8:02 uživatel Zbyněk Bureš <zbures09@gmail.com> napsal:
Thank you for reaching out to us and providing the necessary details regarding the issue with your item. We sincerely apologize for the inconvenience this has caused you.
After reviewing the information and images you provided, we have managed to get the manufacturer to agree on a replacement. We will arrange to have the replacement item sent out to the address associated with your order.
You will receive a confirmation email with the tracking details once the replacement has been dispatched. We aim to have this resolved for you as quickly as possible.
If you have any further questions or need additional assistance, please do not hesitate to contact us.
Thank you for your patience and understanding.
Kind Regards
Just to update you, the replacement motor has now been sent out to you. You can track the progress here - https://www.trackingmore.com/track/en/YT2426921272104419
Any issues, please let me know
Kind Regards
