Order Number: UT-69907
Product Name: Betafpv Air65 Freestyle
Brand: BetaFPV
Motor does not spin when armed can see on wire to the aio not soldered fully.
If yo wage the motor wires it does connect .
Sorry to hear about this issue. Just so I understand correctly…
The one motor wire does not seem to be soldered on correctly, but everything else seems to work as if you hold the wire down the motor works?
If this is the case, could you send over another image that can clearly show this as the photo you received is not very clear and I cannot make out which motor wire has a bad connection.
Kind Regards
Tried uploading video but it will not allow me if the wires are wiggled the motor spins.
If you look closely at the picture you can see a small bit of exposed wire.
It’s needs to be returned and corrected or replaced.
Any photo I try to send is rejected as going against the comunity standards.
Thanks and sorry about that for some reason the system picked up the images as NSFW!
From the image it looks like the one wire may be very thin, are you able to resolder this on yourself as there is enough play in the wire to do this? As this should get the issue sorted for you. If not, let me know so we can look into alternative options to get you back into the air ![]()
Hi Alex
Thanks for the response I would much rather just send it back and have it corrected once and for all if that’s ok.
Thank you for reaching out to us regarding your order. In order to assist you further and generate a Return Merchandise Authorization (RMA) for your request, could you please confirm your complete order number? The number you provided, 69907, appears to be missing the last digit.
Once we have the correct order number, we will promptly send the RMA to your order email.
Thank you for your cooperation, and we look forward to assisting you.
Hi Alex
This is the order number.
Order Number: UT-699073
Hello Jamie,
Thank you for providing your Order number. We will be sending you an email shortly with detailed return instructions.
Best,
Isel ![]()
Unmanned Tech
