TL;DR: Need to reset your Happymodel Mobula8 O4? Download the official Betaflight 4.5.1 factory dump or the custom Nick Burns review tune below.
The Files
Quickly restore your drone settings. Click the links below to download.
1. Factory Default Settings
The original “out-of-the-box” configuration from Happymodel. Best for resetting to stock after a bad flash.
Mobula8-O4-dump-file-for-Betaflight-4.5.1.txt (38.1 KB)
2. Nick Burns Review Tune
The exact tune used in the Nick Burns review video. Best for a smoother freestyle flight and that “locked-in” feel.
Final-factory-dump-file-of-Mobula8-O4-for-Betaflight-4.5.1.txt (38.1 KB)
(Note: Both files are for Betaflight 4.5.1. Ensure your firmware version matches before applying.)
How to Restore Your Mobula8 O4 Settings
Follow these steps to safely apply the CLI dump:
- Connect your Mobula8 to your PC and open Betaflight Configurator.
- Navigate to the CLI tab (Command Line Interface).
- Open the text file you downloaded above.
- Copy all text (
Ctrl+AthenCtrl+C). - Paste the text into the bottom command bar in Betaflight (
Ctrl+V). - Press Enter and wait for the text to stop scrolling.
- Type
saveand press Enter. - The flight controller will reboot. You are now ready to fly.
Frequently Asked Questions (FAQ)
Why do I need the Nick Burns tune?
The stock Mobula8 O4 flies great, but reviewer Nick Burns tweaked the PIDs and filters to handle the extra weight of the O4 Air Unit more smoothly. Many pilots prefer this “locked-in” feel for freestyle flying over the default factory tune.
Will this work if I’m on Betaflight 4.4?
No. These dump files are specifically for Betaflight 4.5.1. If you are on an older version, please update your firmware first, or these settings may cause errors (especially with the unified target mappings).
My OSD isn’t working after the update?
The Mobula8 O4 uses the DJI O4 Air Unit which requires the correct MSP settings on the UART ports. These dump files include the correct “MSP + DisplayPort” configuration. If you still have issues, check that your Air Unit is powered and the RX/TX wires are secure.
Still need the drone?
If you are reading this because you bricked your FC beyond repair (we’ve all been there), you can grab a replacement unit here:
Buy Happymodel Mobula8 O4 Micro FPV Whoop
Happy Flying!
- The Unmanned Tech Team
