Deepspace Roc7 long-range FPV: does a 7.5in quad fly like a 5in?
Rimzler’s latest escapade with the Deepspace ROC7 long-range FPV quad reveals whether this hefty 7.5-inch wonder can keep up with its nimbler 5-inch counterparts. Spoiler alert: it doesn’t quite match the 5-inch’s daintiness but flirts closer to a 6-inch in handling, all while maintaining a sturdy build and impressively quick GPS lock. With flight times sitting between 11 and 14 minutes on sensible 6S lipos, it’s as if the ROC7 has taken a page from the endurance athlete’s handbook.
Inside the box, you’ll find everything from propellers to camera mounts, and the overall impression is that of solid craftsmanship—aluminium canopies and TPU side panels included. Notably, the dead-cut frame design ensures your cinematic shots remain unblemished by pesky props, which is a nice touch for those looking to capture sweeping vistas without an aerial obstacle course.
Flight tests confirm that the ROC7 offers a predictable ride, although some aerodynamic quirks do rear their heads during tight turns. You won’t be pulling off stunts like a seasoned freestyler, but for capturing those stunning landscapes or cruising along tree lines, it shines. Just remember, the right battery size can significantly alter its personality; lighter packs make it lively, while heftier ones instil a sense of stability.
In essence, the ROC7 is a fine choice for pilots yearning for a blend of range and responsive handling without the weight of an all-out cine rig. If you fancy a drone that can balance endurance with a dash of agility, the ROC7 may well be your next flying companion.
For a deeper dive into Rimzler’s findings, check out the video here:
