Hi there.
My mini quad on hover is bouncing. So too little throttle and it lands, too much and I gain altitude. Is it my motors need to be increased in betaflight?
You will almost constantly need to adjust your throttle input as so many variables are changing. Unless you have the right sensors and modes enabled, it will ‘bounce’ and wander on its own. And as the voltage drops slowly, less power will go through the motors at the same throttle input so bare that in mind too! Just be prepared to constantly be on the sticks.
Just sounds like you haven’t got to grips with throttle control yet for the gt2 at least
Hi guys. Thanks. Your right. Just a balancing act. Rotor riot quads seems much better tuned. I’ll get my flying sorted then start fiddling with pids.
