BLHELI SERIES ESC 20A and BLHeli Suite
Hi davy.
Is it possible to swap the whole arm and esc from front to back, or side to side without the soldering. in the video the man mentions about having to solder a wire on esc to flash the bootloader that’s maybe why you can’t get esc’s to be seen.
If not I could only suggest the soldering option unless you have bullet connectors on motors :expressionless: if not I’m sure @unmannedtech1 know how to doit :sunglasses:
Thanks perry
