Are there any fpv cameras I can upgrade the vortex 250 with simply by unplugging old camera and plugging in new camera?
Hey, yeah it is, but a few things you need to double check first.
- Make sure the new camera you get works at the same voltage as I think the vortex 250 uses a 5V supply for camera (I think).
- Depending on the camera you might need to solder some new cables/connectors, but this is fairly easy (and something you will eventually be very good at in this hobby ;))
Thank you very much for the information and taking the time. I appreciate your help.
Mike
Not a problem, if you run into any other issues just ask :-). (better than
frying a camera)
Very kind of you to offer your expertise. Thanks again.
