I am building a heavy lift H pattern Quadcopter. MTOW approx. 120kg… 10 ft long- 3ft wide. It has four electric motors… each has 80kg thrust at full throttle and 43kg at 60% throttle. electric UAV motors. each motor has an 88.8v 22000mAh battery. I am using the orange cube+ flight controller and appropriate software
I am looking to hire a knowledgeable person to help set up the flight control system and plan missions in Mission planner, etc. Also need recommendations on LIDAR, etc. to use autonomously.
Contact Steven at 815.993.0963
That sounds like an impressive build! To help you find the right expert, could you clarify:
- Are you looking for a remote consultant or someone local? If local, where are you based?
- Do you need someone with specific experience in Cube Orange+ and Mission Planner, or would general PX4/ArduPilot expertise suffice?
- For LIDAR recommendations, do you need obstacle avoidance, terrain following, precision landing, or all of the above?
- Any budget range for hiring the consultant and purchasing sensors/equipment?
HI, I am based in northern Illinois. Consultant or local local/close would be preferred. I have a couple orange cube+ controllers so I assume that someone who knows that would be the best.
My budget for the needed/correct sensors, etc. is open. So is consulting fees.
We are based in the UK, but if you can share some more details on the project we will be happy to discuss more, you can contact us directly via our helpdesk if you prefer to communicate privately instead of on this open forum ![]()
I sent a message to your help desk.
- ALL OF THE ABOVE…
