Order Number: UT-748510
Product Name: Runcam Thumb 2-Nd-128-Zz
Brand: RunCam
RunCam Thumb 2 does not power on through USB or through JST connector. I wired the Thumb up to the 5v out and ground on my FC, and when I turned on the quad it powered up for about 5 seconds and recorded. It then turned off and hasn’t turned on since. The connections are definitely to 5v out and GND.
I’ve tried powering it through USB as well as the JST connector. It does not take power out of either. I triple checked the connections soldered to the FC, they should be good.
Hi Dylan good day,
I am sorry to hear you are struggling with your action cam. I can’t see anything obvious from what you have mentioned, so I have reached out to Runcam directly and have asked their engineers to take a look for us.
As soon as I get some feedback from them I will come back to you.
I do apologise for the delay, I will try to get this resolved as quickly as I can.
David
Hello. Has there been any update on this?
