Hi people
Does anybody know if 5 inch props will fit the Falcon 180?
Its currently got 4inch and motor to motor they nearly touch but the mounts are at 10 degrees so if i fit 5 inch they will probably overlap, is that an issue?
thanks
Hi people
thanks
Unfortunately 5 inch props won’t fit on the Eachine 180! 4 inch is the max size for this Quadcopter.
Hope this helps
Overlapping is an issue
At some point the tips will touch and at about 25,000 rpm they will shatter and your quad will just fall from the sky
Steve
yea i dont want that hahaha
Thankfully amazon prime pulled through and delivered some 4 inch props before i went flying
Thanks guys
