FPV Camera on BetaFPV Pavo Pico II: O4 Lite or Pro — Which to Saddle?
The BetaFPV Pavo Pico II has entered the ring, and now you’re faced with the delightful dilemma of choosing between the DJI O4 Lite and O4 Pro cameras. Spoiler alert: your choice could mean the difference between smooth-as-silk footage or a jello fest worthy of a children’s party. The O4 Lite is your friend for gentle flying, providing nearly no jello and a pleasant experience at about 53 grams. Meanwhile, the O4 Pro, while boasting better image fidelity, adds a weighty noise that this tiny whoop simply can’t handle in aggressive acro.
In terms of hardware, the Pico II has undergone some lovely revisions—think stiffer frames, wider carbon rails, and an impressive modular camera system that allows for quick swaps. You’ll find it easy to transition between camera assemblies, setting you up nicely for future BetaFPV models. However, keep in mind that if you fancy a bit of acro, you might want to steer clear of the O4 Pro on this frame; go for the Pavo 20 Pro or Darkstar 22 instead if you’re feeling particularly frisky.
Flight times on the 2S 550mAh battery can stretch from four to five minutes, depending on how hard you push it. But remember, the heavier O4 Pro will sap your endurance quicker than a Brit at a tea party without biscuits, while the O4 Lite keeps things tidy and efficient.
So, what’s the takeaway? Use the O4 Lite for all your cinematic shenanigans, avoid the O4 Pro unless you’re after a specific mission, and don’t forget to tweak that tuning before blaming the hardware for any oddities. For those seeking power, it might be time to consider a slightly bigger platform.
https://www.youtube.com/watch?v=QneLOeNLckI
