Hi I recently bought a iflight nazgul eco DJI 04 . Which flies perfect. I’ve been flying with the DJI goggles 2 and controller 3.
I’ve thought about changing my transmitter to elrs instead. As thought about if power goes to video goes then power to controller would also go , so might be best to have on separate systems? Is it worth having separate or are they so reliable I wouldn’t have to worry about losing power.
And if I do change , what transceivers are recommended for elrs that you sell?thanks
Hi good day,
Thanks for reaching out, and great to hear you’re enjoying your iFlight Nazgul Eco with the DJI O4 system — that’s a solid setup.
You’ve raised a valid point about potentially separating your RC link from the video system to add redundancy. While the DJI system is very reliable and most pilots run both RC and video off the same main battery, in rare cases where the flight battery fails or disconnects mid-air, you could lose both video and control simultaneously.
Many experienced pilots opt for ExpressLRS (ELRS) as their RC protocol due to its exceptional range, low latency, and flexible fail-safe options. It’s a worthwhile upgrade, especially if you’re looking to separate your control link from your video system or just want to future-proof your gear.
