I am looking to get started, I want to buy a EMAX Tinyhawk III Plus Freestyle Drone (RTF Analog) set but would the goggles and controller be comparable with a air75? I would like to have them both one for indoor one for outdoor.
The set says ELRS so I’m taking it if the air75 was elrs then it would work?
Hello,
Yes, you’re spot on — the EMAX Tinyhawk III Plus Freestyle RTF uses ELRS, so as long as your Air75 is also ELRS, you can bind it to the same controller. The goggles in the RTF kit will work with both as they’re standard 5.8GHz analogue.
Great choice for indoor/outdoor flying!
Best regards,
Diane
