SpeedyBee 5.8GHz Analog Goggles Receiver
Is the SpeedyBee 5.8GHz FPV Goggles Receiver Module compatible with Eachine EV300D goggles ?
We don’t carry the EV300D goggles, so I can’t be certain, but given that the SpeedyBee RX module is compatible with FatShark and shares the same pinout and form factor, it should work with your EV300D units. The only potential issue might be whether the plastic housing of the module fits your goggles. In the worst-case scenario, you could remove the module from its yellow casing to ensure a fit, although I anticipate that won’t be necessary.
Kind Regards
