Product Name:
Brand:
I bought the DarwinFPV Tiny Ape Freestyle Frame from aliexpress and i have t motor 1103 8000kv i was pretty sure it would fit the frame but the holes dont align up, in your discription of product it states can use 2.5inch prop, would my motors fit the frames you have in stock?
We apologize for any inconvenience you are experiencing with the motor fitment. The DarwinFPV Tiny Ape Freestyle Frame is designed to accommodate 2.5-inch propellers, but it appears there may be a compatibility issue with the T-Motor 1103 8000KV motors you have.
To better assist you, could you please provide the following details:
- The exact measurements of the mounting holes on your T-Motor 1103 8000KV motors.
- Any photos showing the alignment issue between the motor and the frame.
This information will help us verify the compatibility and provide you with the best possible solution. If it turns out that the motors are indeed incompatible with the frame, we can suggest alternative frames or motors that will work together seamlessly.
Kind Regards
