hi i wanted aime advice which motor size to get example 1750kv ir 1950kv for a 5 inch build thanks
Hi good day,
This will depend heavily on what you intend doing with the drone?
LR, freestyle or racing as a start?
For general applications like freestyle or racing a 2207 or 2306 are good sizes to consider. The KV of the motor is first off determined by the battery cell count so either 4S or 6S generally. that will get you into the correct KV range for the voltage, then you can go up or down slightly depending on your preference.
Here is a really nice explanation of how motor parameters affect performance:
https://www.youtube.com/watch?v=uvyi6hPIt8w
Chris has done a number of really good videos explaining various concepts around motor specifications, I’d definitely have a look at his content.
Hope this helps.
David
