Hi there. I have the Imax B6 mini battery charger and I want to connect it to my PC - is there a special cable I need to do this/software I need to download?
Cheers.
Hi, you can indeed connect the charger to the computer (to monitor voltage and other data) and you can do this by following the instructions below:
- Download the charger master V2.02 from our page listing (it’s at the bottom under ‘Software’).
- Open the charger master, connect the charger to the PC using a USB cable, power on the charger and on the bottom left it will show " xx connected " which means that you can set the parameter value on computer etc.
Cheers!
