YANGDA Sky Whale heavy-lift electric VTOL drone is specially developed for LiDAR mapping and long-range cargo delivery & transport. It comes with four lift motors and one fixed-wing motor, which will allow the fixed-wing VTOL to ascend like a quadcopter. Once in the air, the aircraft transitions to horizontal flight as a push-prop fixed-wing.
Heavy-lift and long-endurance
Sky Whale VTOL drone can fly 120 minutes with 6.5kg payload and 90 minutes with 10kg payload.
Fast deploy
The fixed-wing UAV is adapting the most advanced quick-detach technology on both airframe and cable connector, making assembly and disassembly becomes super easy. In this case, the Sky Whale VTOL plane can be set up in 3 minutes by a single man.
Waterproof
Thanks to its anti-water design, the Sky Whale VTOL drone is waterproof and can reach an IP54 rating.
No piloting skills needed
The long-range VTOL drone can conduct a fully autonomous flight plan without human interaction.
