Order Number: UT-725771
Product Name: Speedybee F405 40a Blue Jay 25.5x25.5 Aio Flight Controller
Brand: SpeedyBee
can not use 2 efc ,can not run motors
can do eny thing as it has a heat shield on it
Hi good day Neil,
Are you able to flash firmware to the ESC?
Can you send me some photos of the top and bottom sides of the AIO so I can take a look?
David
Hi Neil good day,
I picked up your chat ticket with our Bot. I emailed you back on the 16th of this month regarding your initial ticket you created for the AIO.
Would you be able to send us a few more details so I can try to get this sorted out for you?
What are you using to try flash the ESC?
Have you been able to flash firmware to the ESC?
I understand providing these details is a bit tedious, but this helps with consulting with the manufacturer and getting to a resolution as quickly as possible. Usually, if the product is faulty we can get it replaced without needing you to return or send it back to us.
We consult with the manufacturer concerned purely to get sound advice on the root cause of the problem.
I hope this helps.
If there is anything else I can asssit with please do let me know.
David
no point off photo has heat sink on it used the right program esc configurator cant get to esc
Hi Neil good day again,
I spoke with Nathan about the issue you have been having here, our drone engineer, he asked if you are able to flash indiviaul ESC’s? And not try to flash them all in one go.
He doesn’t think it is faulty as in his experience if they are faulty usually you can’t recognise any of the individual ESC’s.
Nathan suggested checking if you are flashing the correct FW and version as this can often lead to odd issues like this.
Please let me know if this helps?
David
yes have i no what im doing have done it before a lot lol cant get to esc ,it has heat sink on i was going to try c2 interface but cant
Thanks for the quick reply and confirming your experience. Understood about the heat sink potentially blocking direct C2 access, although typically flashing via Betaflight/INAV passthrough using ESC Configurator shouldn’t require using the C2 pads directly.
To help narrow this down, could you clarify a couple of things from your latest attempt:
- ESC Detection: When you connect to ESC Configurator (with the LiPo plugged in), does it detect any of the ESCs, or does it fail to connect to all of them? (e.g., Does it show 3 ESCs and fail on one, or does it show “0 ESCs found”?)
- Individual Flashing: Did you get a chance to try reading/flashing each ESC individually within the configurator, rather than using the “Flash All” option? Sometimes one problematic ESC can stop the whole process.
- Firmware Check: Can you confirm the exact Bluejay firmware version you are trying to flash? Just want to ensure compatibility.
Also, let’s try checking the basics via the flight controller software:
- Betaflight/INAV Connection: Does the flight controller connect successfully to Betaflight Configurator (or INAV, whichever you’re using)?
- Motors Tab Test (Props OFF!): If it connects to Betaflight/INAV, can you go to the Motors tab, enable the safety toggle, and carefully try spinning each motor individually using the sliders (ensure a LiPo is connected)? Does this work for all motors, some, or none? This tests the basic communication between the FC and ESCs.
Regarding the heat sink, we generally don’t recommend removing it unless absolutely necessary, as it’s there for thermal management. Standard flashing via passthrough shouldn’t require its removal.
Let us know the results of these checks, particularly points 1 and 5, as that will give us the best indication of whether it’s a configuration issue, a connection problem, or potentially a hardware fault with one or more ESCs.
Kind Regards
k thank in work flat out will have a go before friday and get back 2 u thanks
Hello Pitbullfireblade,
Thank you for reaching out and letting us know about your current situation. We understand that you’re busy and appreciate your efforts. Please feel free to get back to us once you’ve had a chance to test it out. If you encounter any issues or have further questions, don’t hesitate to reach out. We’re here to help!
just 2 esc working tried 2 flash 1 bye no joy the flash i am using is j-h-40 bluejay
Hi good day,
We don’t seem to be coming right with this ESC, please can you return it to use and I will ask Nathan to take a look at it. Please can you return the item, along with the original packaging, documentation and any ancillaries or accessories.
Your RMA number
A link to our RMA form
Remember to complete the RMA form and initiate your return within 30 days. If you have any questions, feel free to ask them in this thread.
Hope this helps.
David
