Order Number: 729970
Product Name: Goku Gm10 Nano V3 Gps W/Compass
Brand: flywoo
Hello, I’ve only now gotten around to installing this today I believe it’s DOA, I’ve used these gps modules for a long time, and this one heated up extremely hot with no light at all. Double-checked the wires and even tried on another flight controller with no luck at all. Ive never had one heat up like that before, there was no smell or smoke but I unplugged it asap
Tried on another FC, Double checked wires and set up. Used a smoke detector when first plugging in also.
Thanks for reaching out, and I’m really sorry to hear about the trouble you’re having with the Flywoo GPS module, especially since you’re experienced with these units. It’s definitely frustrating when a new component doesn’t work as expected right out of the box, and the overheating you described is certainly concerning and unusual.
I appreciate you letting me know the troubleshooting steps you’ve already taken – checking the wiring, trying another FC, and using a smoke stopper is exactly what we’d recommend.
You’re right, excessive heat like that typically points to an internal short. The challenge we sometimes face is that manufacturers like Flywoo test these units before shipping (as they need to flash firmware). Because of this, when a fault occurs, their default position is often to suspect external factors first, such as incorrect wiring, soldering issues, or incorrect voltage/polarity, as these are common failure causes they encounter.
To help me build the strongest possible case for you with Flywoo and push for a replacement, could you please send over a clear photo showing how the GPS wires were connected to your flight controller? Knowing the specific model of the flight controller(s) you tested it with would also be very helpful.
This information isn’t to doubt your setup – especially given your experience – but rather to proactively provide Flywoo with evidence demonstrating everything was connected correctly. This strengthens our argument that the issue lies internally with the GPS unit itself.
My goal is to advocate on your behalf and get this resolved with Flywoo as quickly and smoothly as possible. Let’s get them the info they’ll likely ask for upfront to speed things up.
Thanks for your help with this.
