Order Number: 114983
Product Name: Frsky X9 Lite
Brand: FlySky
The radio does not turn on with batteries inserted. The batteries 18650 Lion cells. The battery compartment has spring battery, and I made very sure that the orientation was correct.
I also used some wire on the springs before inserting the cells, and then using a voltmeter. The voltage showed just over 8 volts.
This showed that the power was connected to the radio. I assume that this means that the fault is internal to the radio.
Ref the last answer I gave.
Hi good day,
I’m really sorry to see you are struggling with your radio like this.
Can you please provide me with the order number for this item. The number quoted previously is the ticket number and not the order number associated with your purchase.
Hope this helps.
If there is anything else we can help with please do let us know.
David
