Nitro Nectar NX69 1S Battery: 69.6% Conductivity Gain for Whoops
The Nitro Nectar NX69 1S Battery has arrived, and it’s not just another pretty pack. With a staggering 69.6% increase in theoretical conductivity over the previous BT2.0, this battery is designed to deliver current like a pro. We’re talking more oomph for those punch-outs and steadier power that doesn’t require an afternoon spent swapping chargers. The NX69 connector is backward-compatible with PH2.0 chargers, so you can keep your old kit—no need to break out the soldering iron unless you fancy it.
Real-world testing reveals an approximately 4.8% boost in peak current—let’s be honest, you’ll feel that in your throttle response. This isn’t merely academic mumbo jumbo; it’s about making your tiny whoops fly better without any of the usual faffing about. Plus, at the same price point of $16.99 for a set of four 300mAh cells, you won’t need to rob your piggy bank for this upgrade.
Why bother with a new connector, you ask? Well, BT2.0 had its day, but as we’ve seen, cells are evolving faster than a soap opera plot twist. The NX69 allows full current delivery from those snazzy new high-discharge cells without bottlenecking performance.
If you want to delve deeper into the nitty-gritty, there’s a video that covers all the details. Grab your cuppa and give it a watch if you’re keen on ensuring your whoops are powered up to their full potential.
