Hi everyone, I wonder if you can help me
I am having a problem with my Mobula7. It starts up fine with all the right beeps and chirps , even the right beeps when I arm it but then when I try to take off it makes the same beeps as arming it does when I raise the throttle and doesn’t take off. Everything checks out in betaflight , transmitter and battery limits included and I am at the extent of my knowledge.
I don’t know I haven’t tried it with motor stop enabled. But they run up on the Betaflight motor tab just fine and everything looks good when I do a status check in the cli tab too
Solved. tmac@tmacfpv.com solved the problem for me. The PID loop frequency was to high which caused the CPU load to be running at 100% so I changed the PID loop to 4K and the CPU load went down to 24 % and away it fleww. So thank you Tmac
