I just received a brand new diatone rabbit 239 NX. Diatone sent me a new tune in a diff file.
Can I copy and paste this defile into the CLI line?
I’ve been reading and been told that you cannot copy and paste from 3.5. anything to 4.0.
Have they worked this problem out in Bettaflight ?
A post was merged into an existing topic: 't install final question before I proceed?
version
Betaflight / FURYF4OSD (FY4O) 3.5.1 Sep 8 2018 / 05:21:25 (d9fb5ca13) MSP API: 1.40
board_name FURYF4OSD
manufacturer_id
name
name diatone
resources
mixer
servo
servo mix
feature
beeper
beacon
map
serial
serial 2 8192 115200 57600 0 115200
led
color
mode_color
aux
aux 0 0 0 1900 2100 0 0
aux 1 28 0 1875 2100 0 0
adjrange
rxrange
vtx
rxfail
master
set dyn_notch_quality = 5
set dshot_idle_value = 400
set current_meter = ADC
set small_angle = 60
set osd_warn_core_temp = OFF
set osd_cap_alarm = 500
set osd_vbat_pos = 2497
set osd_tim_2_pos = 2519
set osd_vtx_channel_pos = 2456
set osd_current_pos = 233
set osd_mah_drawn_pos = 2508
set osd_craft_name_pos = 2102
set osd_pidrate_profile_pos = 409
set osd_warnings_pos = 329
set osd_avg_cell_voltage_pos = 2433
set vtx_band = 5
set vtx_channel = 3
set vtx_freq = 5732
profile
profile 0
set dterm_lowpass_hz = 80
set dterm_lowpass2_hz = 160
set dterm_notch_cutoff = 0
set iterm_rotation = OFF
set iterm_relax = RP
set iterm_relax_type = SETPOINT
set throttle_boost = 0
set p_pitch = 45
set i_pitch = 56
set d_pitch = 19
set p_roll = 43
set i_roll = 48
set d_roll = 17
set p_yaw = 73
set level_limit = 35
rateprofile
rateprofile 0
set thr_mid = 100
set thr_expo = 95
set roll_rc_rate = 70
set pitch_rc_rate = 70
set yaw_rc_rate = 70
set roll_srate = 75
set pitch_srate = 60
set yaw_srate = 50
set tpa_breakpoint = 1750
So just copy the first half of the tune ?
Then leave the settings default on Bettaflight 4.0.2?
What I’m picking up from what you’re saying:: copy down to the profile and stop copy at the profile?
Then leave the default setting for profile and PID’s ?
If that’s correct what about dyn notch quality isn’t that a filter ?
By the way thanks for your suggestion.
Why didn’t I think of that !!!
Can you answer my question about the dyn notch quality and should I edit that setting as well out before pasting ?
This Topic has been moved to prevent spam and keep everything together.
