Question : Should I leave out the serial numbers line also ? I have been told not to paste that line also ?
If you could give me your input on the question about the dyn notch quality as well I’d greatly appreciate it.
I’m setting down to work on it after review from you .
Thanks in advance
Paul Lowkater.
Try this:
If the link does not work google :“nw_elf.dll”.
THANKS DNUTS !!!
I JUST GOT ONE OF THE LATEST UPDATED VERSIONS OF THE DIATONE RABBIT NX !!! It’s my second one . I had the older version of this model.
I knew it was out for delivery so I went on gethub to download the latest version of Bettaflight configurator. Then I had this problem with the download !!! .
I’m hoping it was just the file from gethub.
Thanks so much for your help.
Ill try your salution as soon as I can.
Glad i could possibly help
The error occured because your Windows system is/was missing the file “ nw_elf.dll ”.
This can have several reasons. It is possible that you dont have it because Windows 7 does not support it. (Could be… Just try it out)
If thats the case look for a Windows 7 compatible Betaflight version.
OR:
If you dont have a PC in range that is capable of running Betaflight:
-Try using a virtual machine and load linux on it. Its free and most distributions are capable of running Betaflight.
OR:
-Download Betaflight on your Smartphone (I think it is called Speedybee) and use a OTG cable to connect your phone to the flight controller. It depends on the FC but you will maybe have to power the FC seperatly.
Wow thanks for all the tips & tricks suggestions!! I have a bunch to look up and study now !!! I was not aware you could use a smart phone.
I got it all worked out. I just had to use Internet explorer to do the install.
It’s always work with betaflight so far it’s just a little slow on a starter.
Thanks so much you seem to have a vast knowledge.
I HAVE ANOTHER QUESTION :
I have since flashed betaflight 4.0.2 after getting the configurator all worked out. I want to paste a tune that Diatone has sent me. I have been told not to paste since I’m coming from betaflight 3.5.1. That’s what the quad copter had in it from the factory.
So my question is: How do I enter the tune line by line ? : A CLEAN INSTALL AS THEY SAY::
This is what Diatone sent me a diff # tune
version
Betaflight / FURYF4OSD (FY4O) 3.5.1 Sep 8 2018 / 05:21:25 (d9fb5ca13) MSP API: 1.40
board_name FURYF4OSD
manufacturer_id
name
name diatone
resources
mixer
servo
servo mix
feature
beeper
beacon
map
serial
serial 2 8192 115200 57600 0 115200
led
color
mode_color
aux
aux 0 0 0 1900 2100 0 0
aux 1 28 0 1875 2100 0 0
adjrange
rxrange
vtx
rxfail
master
set dyn_notch_quality = 5
set dshot_idle_value = 400
set motor_pwm_protocol = DSHOT600
set current_meter = ADC
set small_angle = 60
set osd_warn_core_temp = OFF
set osd_cap_alarm = 500
set osd_vbat_pos = 2497
set osd_tim_2_pos = 2519
set osd_vtx_channel_pos = 2456
set osd_current_pos = 233
set osd_mah_drawn_pos = 2508
set osd_craft_name_pos = 2102
set osd_pidrate_profile_pos = 409
set osd_warnings_pos = 329
set osd_avg_cell_voltage_pos = 2433
set vtx_band = 5
set vtx_channel = 3
set vtx_freq = 5732
profile
profile 0
set dterm_lowpass_hz = 80
set dterm_lowpass2_hz = 160
set dterm_notch_cutoff = 0
set iterm_rotation = OFF
set iterm_relax = RP
set iterm_relax_type = SETPOINT
set throttle_boost = 0
set p_pitch = 45
set i_pitch = 56
set d_pitch = 19
set p_roll = 43
set i_roll = 48
set d_roll = 17
set p_yaw = 73
set level_limit = 35
rateprofile
rateprofile 0
set thr_mid = 100
set thr_expo = 95
set roll_rc_rate = 70
set pitch_rc_rate = 70
set yaw_rc_rate = 70
set roll_srate = 75
set pitch_srate = 60
set yaw_srate = 50
set tpa_breakpoint = 1750
SAVE
Can you give me a few examples how to enter this tune line by line ?
I have read and heard that if I paste it because I’m coming from 3.5.1 to 4.0.2 it will fly all messed up.
I guess that’s still matters even though it’s a brand new quadcopter?
As you can tell I’m new to the hobby but I’m learning pretty quick.
I didn’t even know how to turn a computer on when I first bought it four months ago!!! Ha ha ha lol !!!
_**[quote=“Lowkater420, post:8, topic:8045, full:true”]
version
manufacturer_id
name
name diatone
resources
mixer
servo
servo mix
feature
beeper
beacon
map
serial
led
color
mode_color
aux
adjrange
rxrange
vtx
rxfail
master
set vtx_band = 5
set vtx_channel = 3
set vtx_freq = 5732
profile
profile 0
set p_pitch = 45
set i_pitch = 56
set d_pitch = 19
set p_roll = 43
set i_roll = 48
set d_roll = 17
set p_yaw = 73
rateprofile
rateprofile 0
set thr_mid = 100
set thr_expo = 95
set roll_srate = 75
set yaw_srate = 50
SAVE
[/quo
Heres a list for all CLI Commands.
https://github.com/betaflight/betaflight/blob/master/docs/Cli.md
This Video shows you what to do and how to do it:
Just try to maybe only take the receiver settings over and spend some time tuning the rest by yourself.
You will learn a lot and flying will feel better with your own tuned stuff (believe me on this one)
‘t install final question before I proceed?
2d - Can I paste diff file to 4.0.2 then paste it as normal - this will remove the PID and filter settings that are dangerous to copy from Question : Should I leave out the serial numbers line also ? I …
version
manufacturer_id
name
name diatone
resources
mixer
servo
servo mix
feature
beeper
beacon
map
serial
led
color
mode_color
aux
adjrange
rxrange
vtx
rxfail
master
set vtx_band = 5
set vtx_channel = 3
set vtx_freq = 5732
profile
profile 0
set p_pitch = 45
set i_pitch = 56
set d_pitch = 19
set p_roll = 43
set i_roll = 48
set d_roll = 17
set p_yaw = 73
rateprofile
rateprofile 0
set thr_mid = 100
set thr_expo = 95
set roll_srate = 75
set yaw_srate = 50
In summation my question is can I copy and paste this file after editing out PID settings, filter settings ?
Also should I leave out the serial numbers line & dyn notch quality setting ?
You can paste it - but you will need to edit it slightly first so that your quad doesn’t try to kill you - or fly to the moon.
Just remove everything between the
# profile
And
# rateprofile
Lines - then paste it as normal - this will remove the PID and filter settings that are dangerous to copy from 3.5 -> 4.0
