Ah, the Voltara Gen2 ESC firmware—a proper upgrade or just another excuse for us to tinker? Spoiler alert: it’s the former. This isn’t your usual half-hearted update—it’s been rewritten from the ground up, boasting a new bootloader, firmware, and configurator all designed with modern FPV madness in mind. If you’re holding on to your old Voltara hardware, you can migrate, but do be careful. One wrong selection could lead to a delightful evening filled with confusion and colourful language.
Performance-wise, we’re talking up to 700,000 eRPM—perfect for those of you who revel in small motors and bizarre builds that make others raise an eyebrow. Compatibility is also on the menu, as Gen2 aims for universal flight-controller support across Betaflight, KISS Ultra, and iNav. Just remember: if you want your ESC to coddle your subpar flight-controller tuning, this isn’t the firmware for you. Gen2 is all about giving you the raw power and feedback you didn’t know you needed.
And don’t fret about setup; the new configurator will guide you through. Just keep your wits about you when migrating—selecting the right hardware is key, lest you sacrifice an evening to the tech gods.
If you fancy a bit more detail or prefer visual aids, check out the video here:
For more insights into ESC choices, our VoltaraRC ESC review might tickle your fancy.
