The RadioMaster TX16S Mk3 Max has arrived, and it’s a beastly bit of kit for the discerning pilot. With a robust feature set that includes Gemini X 2.4/900MHz support, a 480x800 IPS touchscreen, and CNC AG012 gimbals, it’s like putting on your best tweed jacket—fashionably chunky and ready for anything. The upgrade from Mk1 to Mk3 isn’t just cosmetic; it boasts a snappier processor to keep things tidy under pressure, meaning no more lagging behind while you’re trying to impress the neighbourhood with your aerial acrobatics.
What really sets the Max apart is its premium gimbals that feel tighter than a pair of new shoes after a rainstorm. And let’s not overlook the handy spring tension adjustment that means no more faffing about with screwdrivers when you fancy a change. The touchscreen is responsive enough to make you wonder if it’s been taking notes from the latest smartphones, paired with an improved layout that should give even the most finicky pilots a warm fuzzy feeling.
Now, if you’re one of those who shudders at the thought of heft, you might want to consider alternatives like the GX12 or Zorro, both of which wear their compactness like a badge of honour. However, if you value screen real estate and gimbal quality over pocketability—then the Mk3 Max is your new best mate. Just be prepared for some serious hand-stretching if you’ve got dainty fingers; this radio doesn’t mess about in the size department.
So, whether you’re looking to dominate the micro or full-size quad scene, the TX16S Mk3 Max could just be the right tool for the job. It’s got all the bells and whistles and then some, making it quite the solid choice for those who prefer functionality over minimalism.
For the video review, see here:
