What are the power supply requirements for the EP2C70F896I8N?
I can only partially answer this query as the specific power supply requirements for the EP2C70F896I8N are not fully detailed in thr info I have found, perhaps someone else who knows more can help?
Known Power Specifications
The device features multiple power supply pins:
- VCCIO[1…8]: These are I/O supply voltage pins for banks 1 through 8, with each bank capable of supporting different voltages[2]
Configuration Support
The device supports multiple configuration voltages:
- 3.3V
- 2.5V
- 1.8V[1]
However, I cannot provide the complete power supply requirements as the search results don’t contain information about:
- Core voltage requirements
- Current requirements
- Specific voltage tolerances
- Power sequencing requirements
For accurate power supply specifications, you would need to consult the complete power specifications section of the Cyclone II device handbook.
Citations:
[1] [PDF] ALTERA CORPORATION (EP2C70F896C8) FPGA: Cyclone II Family https://datasheet.octopart.com/EP2C70F896C8-Altera-datasheet-7839388.pdf
[2] [PDF] Pin Information for the Cyclone II EP2C70 Device - Intel https://cdrdv2-public.intel.com/655831/ep2c70.pdf
