Oxbot Lumo18 review: DJI O4 Lite tinywhoop that actually flies smooth
The Oxbot Lumo18 has entered the tinywhoop arena and, surprisingly, it can both fly and stabilise—quite the feat! With familiar specs like a lightweight 2S frame, DJI O4 Lite camera hardware, and ExpressLRS, it promises no more of that classic tinywhoop wobble and jello nonsense. But does it deliver? Spoiler alert: it does, mostly.
Unboxing reveals a rather generous kit with spare parts and tools, along with a delightful yet entirely unnecessary RGB strip that lights up like a disco ball. The build quality is solid with its injection-moulded plastic frame, which means it’s less likely to crack under pressure—unlike some of our new year resolutions.
Flight tests are where the Lumo18 shines, even in breezy conditions that would make most drones whimper. It handles acro mode surprisingly well; sure, there’s a bit of noise, but nothing catastrophic. Those keen on filming will appreciate the smooth GyroFlow stabilisation—if you remember to set it to the wide-angle profile, lest you wish to see your footage auditioning for an amateur horror film.
In summary, if you’re after a tinywhoop that doesn’t just flail about but actually captures half-decent video, the Oxbot Lumo18 deserves a spot on your shelf (or the flight path). Just don’t forget to stock up on spare props because, as always, chaos lurks around every corner—or in this case, behind the bushes where the chickens hide.
