Order Number: 7945
Product Name: Geprc Taker F722 45a 32bit Aio
Brand: GEPRC
the flight controller has a smaller mounting then the frame swo id like to return it and buy a bigger flight controller
Order #7945 - Geprc Taker F722 45a 32bit Aio - incompatable size between flight controller and frame
Hi there,
Thank you for reaching out about order #7945. I understand you’ve discovered that the GEPRC TAKER F722 45A 32Bit AIO flight controller has a smaller mounting pattern than your frame, and you’d like to return it to purchase a larger compatible one.
Return Process:
Since this is a compatibility issue, we can certainly help you with a return under our standard policy:
- Return Period: 30 days from the date of delivery
- Restocking Fee: A 3% restocking fee applies to returns
- Return Shipping: Customer pays return shipping for compatibility/change-of-mind returns
- Condition: The item must be in returnable condition with original packaging and accessories
Next Steps:
- Please confirm you’d like to proceed with the return
- Let me know what frame you’re using (brand and model) - this will help me recommend compatible flight controller options
- Once confirmed, I’ll provide you with the return shipping address and instructions
After we receive and inspect the returned item, we’ll process your refund and you can then purchase a compatible flight controller.
Please reply to confirm and provide your frame details so I can assist you further.
Best regards,
Unmanned Tech Support Team
