Order #713436 - Dji O4 Air Unit - ONBoard recording not working
Order Number: 713436
Product Name: Dji O4 Air Unit
Brand: DJI
My dji o4 onboard recording doesn’t work,
every time I click record the amount of minutes I have remaining in internal storage goes down in the goggles but the actual o4 has nothing when I plug it in
I have been through all the settings and tried recording multiple times but I only get recordings on the goggles
Hello there,
To better assist you, could you please provide us the serial number by simply scanning the QR code. This is required by DJI for troubleshooting.
Preview
Best,
Isel :slightly_smiling_face:
Unmanned Tech
Hi isel,
The Serial number Is
9BTKMC400100AK
Hi Alex here, just wanted to check, are you powering your unit just via USB when trying to record, as I don’t think the unit will work properly just under USB power. Have you tested when its powered via at least a 2S battery?
Kind Regards
Hi there,
We just got a reply from DJI. Please see below:
Check the settings in the goggles to ensure that both recording options are enabled? They can navigate to the goggles menu and follow this path: Menu > Settings > Camera > Advanced Camera Settings > Record With > Both/Aircraft/Goggles.
If there is still have issue, please provide a video about the issue.
Video upload link: https://pan-sec.djicorp.com/s/3qmpbSf6JmTdZ4M
Best,
Unmanned Tech
Hello there,
We haven’t heard from you for a week since our last email. May we ask if the has been resolved?
Best,
Unmanned Tech
hi. sorry to dig up an old thread. but I’m having many of same issues kind of. I keep getting the message "Recording aircraft view failed" so I’m thinking I Messed up the file system when I was taking files off of storage.
Hi FPV-GOOGLY-EYES,
Sorry you’re having trouble with recording. What happened when you moved the files may help narrow this down, but it doesn’t establish that the file system is damaged.
Could you clarify a few details?
  • Which Air Unit and goggles models are you using, and are you recording to the Air Unit’s internal storage or a microSD card?
  • Did recording work before you transferred the files? Which computer or device did you use, and did you copy, move or delete files, or format the storage?
  • Which checks have you already tried? If you have a screenshot of the error or know the firmware versions, please include those too.
DJI’s own technical team is the recommended first route for official DJI products; you can contact them through the DJI app.
We’re also happy to help here if you prefer. If you’ve already contacted DJI and haven’t got anywhere, let us know what they advised so we don’t repeat the same steps.
Best regards,
hi, thank you for responding
Yes, I tried reformatting. When I have some time tomorrow after work, I’ll check it out. Thank you for responding again.
So please excuse the brevity, typos and misspellings and don’t forget to consider the environment before printing this e-mail.¯(°_o)/¯
The “Recording aircraft view failed” message usually points to the air unit’s own storage rather than the files you moved off the card, so reformatting is a good first check. When you test tomorrow, record a short clip to internal storage first, then to the microSD separately, so you can see which one fails. If the card was formatted on a computer beforehand, redoing it in the goggles is worth trying. Posting the firmware versions and goggles model once you’ve checked would help narrow it down further.
