Hey I am working on drone by my apm is showing bad compass health
I purchased a apm 2.8 with built-in compass but it was showing bad compass health and I was not able to calibrate after deep research and everything I bought new external gps compass even it is showing bad compass health and I am not able to calibrate pls help me :folded_hands:
Since both the internal and a new external compass show the same fault, the issue is probably not the compass module itself but the wiring, power, or configuration. On the APM 2.8 the external compass shares the I2C bus, so check SDA/SCL continuity and that the GPS cable is seated properly. Also rule out magnetic interference by moving the drone away from speakers, motors, or metal before calibrating. Confirm you selected the correct compass in Mission Planner and that the board is getting stable power. Does the bad health appear immediately on boot, or only once you start the calibration routine?
The boot-timing question matters here. If the bad health shows up immediately before you touch calibration, that points more toward the I2C bus or power than the calibration step itself. On APM 2.8 the external compass rides the same bus as the GPS, so a marginal 5V rail or a loose connector can knock the compass offline at startup. I’d check the GPS cable seating and SDA/SCL continuity as mentioned, and confirm the external compass is actually detected in Mission Planner’s hardware list. If it only fails during calibration, interference is the likelier suspect.
Checking whether the fault appears on boot versus only during calibration is a good way to narrow this down. On my side of things I’d also verify the external compass is actually detected in Mission Planner’s hardware list, since a loose GPS connector or a marginal 5V rail can drop it from the I2C bus. If it only fails once calibration starts, moving the frame away from motors and metal is worth a try. Does the health warning clear after a reboot?
