FpV drone ERA Mini review-ish: the same DNA, smaller (and tighter)
The new ERA Mini is a pint-sized marvel, shrinking the original ERA frame down to a mere 3.5 inches—because who doesn’t like a bit of compression? It maintains the hallmark strength of its predecessor with a moulded nylon front cage that guards your camera like a bouncer at a chippy. Just remember: if you’re choosing between the standard version and the O4 Pro variant, do so based on your camera’s fitment rather than any whimsical fancy.
As for assembly, good luck if you plan to wing it. Pre-fit those captive nuts before closure; you’ll thank us later when you’re not wrestling with screws in a cramped space. And let’s not forget the stack height—measure twice, build once, as they say. The tight front clearance might just put your engineering skills to the test, but hey, nothing says “I love a challenge” like fitting electronics into tight corners.
For those curious about specifics, the bare frame weighs in at a respectable 90.30 grams, making it light enough to keep feeling like a drone and not an anchor. Plus, with the added benefit of readily available spare parts, you won’t be left high and dry if something breaks.
In summary, the ERA Mini offers a robust build for those willing to apply a bit of elbow grease. It’s all about knowing what fits where before you shove everything together and hope for the best.
For the full details, watch the video here:
