The Flywoo DJI O4 Wide Air Unit is here to rescue you from the claustrophobic confines of the original O4 Lite’s meagre 117 degrees field of view—now a much more respectable 159 degrees. Of course, with great power comes great responsibility, and in this case, it means hefting around a rather portly 17.19g instead of the old unit’s featherweight 9.27g. If only physics would take a holiday during FPV marketing campaigns.
This new addition isn’t for those on a strict diet, especially if your 1S micro is already pondering life choices over every extra gram. It’s best suited for builds of 3 inches and up, where the robust image quality and wider perspective can shine without the burden of a tiny thrust-to-weight ratio whispering sweet nothings about optimal performance in your ear.
The onboard storage reportedly boasts a whopping 23GB, which certainly sounds impressive until you remember that verifying these numbers is like trying to find a needle in a haystack—good luck with that! And let’s not forget the lovely edge distortion that might pop up when whipping around tight corners; a minor quibble compared to the overall benefits of the broader view.
In summary, if you’re after a higher-quality image and wider angles at the cost of some heft, the O4 Wide is worth considering. Just don’t expect it to sit comfortably on your dainty micro unless you fancy a bit of a weighty challenge.
Watch the full breakdown here:
