Betaflight GPS Bug: Stop a Flight Controller Freeze Before Take-off
It seems our beloved Betaflight has been caught with its trousers down, as there’s a pesky bug that may turn your flight controller into a rather expensive paperweight mid-air. If GPS is turned on but fails to communicate with its module, you’re in for a thrilling ride—only it’s not the good kind. And before you start thinking about your quad’s return-to-home feature, let me save you the trouble: it’s about as useful as a chocolate teapot in this scenario.
To prevent this delightful disaster, always check your GPS configuration before take-off. Should you discover your OSD elements are playing hide and seek at power-up, do yourself a favour and refrain from launching your flying brick into the wild blue yonder. Betaflight 2025.12.3 has introduced some mitigations, but don’t be fooled into thinking it’s a silver bullet. Keeping an eye on those settings is still your best bet.
For those of you wielding BNF models, you might want to disable GPS settings if there’s no actual GPS module on board—not doing so could lead to an unexpected trip to retrieve your quad from the bushes. If you’re unsure how to check these settings, consult our guide on where to mount a quadcopter GPS module or simply take a few moments to look over your configuration in the Betaflight Configurator.
So, there you have it—a gentle nudge to ensure your pre-flight checks are more thorough than your last attempt at assembling IKEA furniture. Happy flying, and remember: a well-configured quad is the difference between a scenic flight and an impromptu retrieval mission.
