is tghere a way to connect runcam eagle to pc monitor using hdmi? So I can check if its working correctly without buying a new monitor for it? So I can eliminate VTX as the problem.
Thanks,
Steve
Thanks,
Steve
I believe Maplins do a unit which will convert the composite video from the camera to an HDMI signal you can put into a TV/monitor
Alternatively and may be cheaper use a video capture card/stick between the camera and PC
Steve
Cheers Steve,
I may get one for future reference so I can check cameras are working correctly
Steve
