Neutronrc At32f435 Mini AM32 Esc struggling to start motors and desync issues
I managed to flash with the file using ignore mcu layout and slow pre release but it still has the issues with 2 of the motors I have a video but this is telling me new users cannot upload files. 2 motors are working flawlessly and 2 motors are struggling to start
Thanks for updating me and happy to hear you are making some progress.
For the video you may want to upload to a place such as imgurl.com and paste the link here. I can then also share this with the NeutronRC designer to get his feedback.
For those two motors, does this happen even if you swap them around, ie the issue is specific to the ESC output, or a motor.
As if I understand your comment correctly, you say that just struggle to start, but are ok at highter throttle, then you may want to check the startup power setting (and even timing) and see if the issue is improved. I would also suggest you take a few minutes and go through Chris’s great video on all the settings on AM32:
https://www.youtube.com/watch?v=VCIpMOESqmw
Kind Regards
I have tried all ways to correct the startup it also desincs the issues occur when rpm rapidly changes on a bluejay esc the motors work perfectly with no issues I have just tried this even on conservative startup power settings. This is not my first build in fact it is my 6th and I watch every Chris’s videos I do have a good understanding of esc settings and I have tried every startup power and timing combination along with different Pam settings as pwm effects the motor torque even down at a pwm of 8 it is not fixed and at that point it takes 10a just to hover.
(attachments)
Can you please adjust the starting power needs to be adjusted to 150%, as this is required for a 1002 size motor. Let me know how you get on.
Kind Regards
Sorry for the slow reply. The startup power was already set to this. I believe it is an esc issue as 2 motors work no problem on the same settings and flashed to the same version which indicates a hardware issue. That leaves 2 possibilities the esc or motor being the problem. I have soldered the motor to a different esc and it runs without issue leaving 1 possibility an esc issue so I would like to return it and buy something that actually works. It has been 5 weeks of this not working and there has been no meaningful improvement and it just feels we are trying the same things that have already been tried. At one point I could fly the drone it just had a desinc at every high throttle so the improvement to now make the motors spin again seems futile as They spin with the same issue as before
Just to update you on this, thanks for all your time trying to troubleshoot this. Please can you return the item back to us for further testing/replacement.
Kind Regards
How should I begin the return process
An RMA (Return Merchandise Authorization) has been created for your order.
  1. Your RMA number
  2. A link to our RMA form
Kind Regards
I have not heard anything else about the aio or if any troubleshooting has been done since it arrived 3 days ago.
Due to some staffing issues and time off, things are slightly slower at the moment, but if tracking shows that we have received the item back it should be processed shortly.
In the meantime, if you can provide the tracking number I can then chase this up with our warehouse team to confirm, and we can get the replacement shipped out to you (hopefully today, otherwise should be tomorrow)
Kind Regards
I did not realise you still had staffing issues. thank you for your help. The tracking number was QQ986074909GB.
Just wanted to let you know that we shipped the replacement out to you on the 6th Sept, so hopefully its all working now. Any other issues, please let me know.
Kind Regards
