Flight controller wont connect to betaflight and not recognised by my pc
Hi
My f3 omnibus mini will not connect to betaflight and give the error “failed to connect to com port” and on my pc it says USB device not recognised. I have tried impulse rc and zadig where i cannot find the stm32 driver to install. Also, have installed the driver from the betaflight home page (CP210X)
Please help
Does your omnibus get hot when plugged in via USB? And do you see any LED’s flashing when you plug it in?
There is a link to the stm32 driver on the front page of the betaflight configurator towards the bottom left hand corner
no it doesnt get hot, it shows a solid red led
I think that only works for windows 7 and 8 I have windows 10. Nevertheless ill try it again.
Have you tried the impluseRC diver fixer? I find this tool to be the easiest to fix any driver issues on windows.
I had a similar issue on my windows 10 laptop…
I’ll try and do a rough guide on how I fixed it tonight when I get to my computer.
OK thanks that would be great
This is a very rough video.
Watch it till the end its only 3:40m then ask any questions.
This is me downloading and installing the ST32 drivers.
@2:48 I plug in my quad
@2:52 I reinstall the drivers, useful if it doesn’t work or stops working.
You may find at this point the drivers have installed and work correctly and you can skip this bit.
i cant seem to find the video
It kind of helps… if i … link the video.
ok, I followed the steps in your video except when installing the stm driver it didn’t ask me which users to install the driver for which was @1:43 in your video and it didnt ask me if i wanted to receive the latest updates(i dont know if it makes a difference)
But, when i did try to install the stm, it asked me if i wanted to modify, replace, or delete(i clicked modify) Also when I try to install it goes up to “preparing to install” @1:15
Also i cannot find the stmelectronincs file (at the end of your video) to updates the driver and dont have a st virtual driver under my ports (com)
Overall it didnt work
That’s a feature of my machine. you did the right thing just to carry on.
Modify is fine… replace may have been bettee
The com port only shows when you FC is plugged into your computer
Below is the file path the drivers
C:\Program Files (x86)\STMicroelectronics\Software\Virtual comport driver\Win7
I used your file path to download the driver but still had no luck
Ok the last option I can think of.
Is trying to remotely install the drivers for you and connect to betaflight.
ok lets do that then.
It would be fine to do it tommorow if its too late now.
I have a similar problem. I have 3 drones - a Wizard, trashcan, and mantis. None of them even register when I plug them into a USB port. I don’t get the audible chime when you plug something in. I’ve tried many of the steps above without success. A virtual COM port does not show up in the Windows device manager, or in either of the utilities above. Is there a way to clear them out and start over? Everything was working until yesterday. Thanks for the help
Try a different USB Cable…
Some USB cables do power only and not data.
I find it strange with 3 different none of them connect,
Delete the driver and restart pc , also make sure your using a data cable and not a charging cable
