Was thinking of buying a tali h500. Will my devo f7 work with it? Or do I need 12 channels (devo f12 range) Thankyou
It is technically possible, but the range of the Devo F7 is rather poor when compared to the other non f series devo radios.
Also with only 7 channels you will loose some functionality with the H500. Also if you use your own radio/receiver with the H500 you will need to open it up and configure the radio and the hexacopter via the setup software to get it all working properly.
