FY 41 AP Lite and Hacker X70 SB pro ESC
Hi can anyone help me? I have installed the FY41 lite in my Valenta 4m electric glider.
When I plug the throttle in to the AP the ESC brake function stops working so the prop does not fold! I have tried upping the throttle gain on the AP to 90% but still no joy.
Any suggestions welcome!
I think that I already replied to you via email about this issue, but just incase anyone else has a similar issue/question here is the solution:
My suggestion is that it sounds like the output signal from the FY41 AP is not the same as the range on the ESC which would by why the brake is not working. So you should try and calibrate the throttle range of your ESC again once its connected to the FY41.
Hope that helps
